305/350 Differences
Transmission: 4L80E/4L80E
No, the cranks start off life the same. They are balanced slightly different depending upon whether they end up in a 305 or 350.
The basic difference is the diameter of the cylinder bore. The 305 is 3.736" stock, and the 350 is 4.000" stock. The castings are different because of the bore difference.
There are other detail differences such as combustion chamber size, valve size, etc., that varies even between 350's and 305's. But, the bore is the distinguishing difference.
Numbah-1
Sep 12, 2015 08:57 PM
