1.6 RR Questions
Old Mar 16, 2007 | 12:09 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
1.6 RR Questions
I've been doing my reasearch on 1.6 roller rockers.
A lot of guys like Crane Gold and GMPP. However, these are aluminum, and I've heard aluminum get bashed on here.
My L98 is virtually stock. Are the Comp Cams (CCA-1318-16) any good?
I've read that i need to get the ARP rocker studs if I go this route. Exactly which studs (part number please!) do I need?
Also, is my engine set up for push in or screw in rocker studs? If its push in, can I have it modified to work with the ARP screw in bolts?
Finally, should I have the valve springs replaced? (My engine has just over 51 or 52K on it.) If so, what springs should they be replaced with?
Any other modifications/replacements while I'm at it?
Thanks!
Bill
Old Mar 16, 2007 | 12:33 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
If they're the stock heads, my understanding is that they're press-in studs - and yes, they can be modified, you just need to pull the heads, pull the studs, tap the heads for the screw-in studs, & reassemble all of it...
Cameeeero
Sep 18, 2015 04:00 PM
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
