stock 90 degree spark plug wires
Old Mar 16, 2007 | 12:51 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
i put on some hedman lt headers and need some plug wires... anyone know of a stock hei equiped sbc that had 90 degree plug wires on it? i figure a truck would but every set of stock wires i have looked at so far have some 90 degree and some straight. just need some cheap stock wires to get the car running tomarrow.
Old Mar 16, 2007 | 01:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You should be able to find an inexpensive "universal" set that has 90 degree boots. Failing that, you can just buy new terminals and boots relatively cheaply and crimp them on to a set of wires.
Old Mar 16, 2007 | 01:03 PM
dustpusher's Avatar
Car: 88 IROC-Z
I had a 92 gmc and they were all 90 boots.
Old Mar 16, 2007 | 02:01 PM
gapimpin's Avatar
Engine: 383 LT1
awsome just had oreillys verify it for me so ill be picking up a set of plug wires for a 92 gmc 1500 tonight... thanx dust
Old Mar 16, 2007 | 02:04 PM
dustpusher's Avatar
Car: 88 IROC-Z
Your welcome. Glad i could help.
Old Mar 16, 2007 | 02:46 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
all the 70s cars and trucks were 90 degree through 79 with the big below the plug style manifolds, extremely common
good luck
Old Mar 16, 2007 | 06:21 PM
gapimpin's Avatar
Engine: 383 LT1
dropped by oreillys got wires from a 92 gmc cap and rotor from an 83 camaro ngk tr55 plugs and a baterie cable for my remote mount solinoid... took 45mins... that guy was dumb as a brick. i was trying to get a 180 thermostat he kept bringing me 195 saying thats the only one that was made for it. last time the guy was cool other than the fact that he was a ford guy but even then he knew all parts on an sbc are interchangable.
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
Zachattack0925
Aug 12, 2015 09:52 PM
djmarch
Aug 9, 2015 05:27 PM
