Bent fuel line
Old Mar 17, 2007 | 04:31 PM
D BERRY's Avatar
Car: 89 Camaro RS
Engine: LO3
Axle/Gears: 273 pegleg
Bent fuel line
I need a pic or diagram of the fuel line on a 89 RS with a TBI and a 305. Not really sure if it's the fuel line or the return line. Looks like it was removed and thrown on the ground and driven over a few times, its kind of strangely bent and has some kinks in it. It's the line that exits from the back of the TBI on the passenger side, anybody have a good one they'd like to get rid of maybe?
Dave B
Old Mar 17, 2007 | 06:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
This good enough?
Old Mar 18, 2007 | 08:18 AM
D BERRY's Avatar
Car: 89 Camaro RS
Engine: LO3
That is absolutely perfect. Looks like I need number 38, figured it probably looked a lot like 39 since they start at the same spot and end at the same spot. Wonder what the new cost is??
Dave
Old Mar 18, 2007 | 01:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The original P/N was 10055815, but it's probably no longer available.
Old Mar 18, 2007 | 01:19 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
When I bent my Fuel Line, it was such a bitch to replace. I had to go to the junkyard and I could not find a nice 305 tbi Engine with functional fuel lines to remove. I then found a nice fuel line on a 1991 pontiac firebird I removed the passanger side fuel line from that and took it home and insstalled it was about $3.00 at Pick your parts (Scrapyard) Good luck! They are easily bendable so be careful when you install it and make sure you do not over torque it. Take off the fuel cap if you are working in a hot enviroment that way the gas tank can vent, if not it will just start pouring out using any opening such as the open fuel line.
Old Mar 18, 2007 | 05:17 PM
D BERRY's Avatar
Car: 89 Camaro RS
Engine: LO3
Yep, think your right about the junkyard, thanks for the part number and the advice on venting the fueltank.
Dave B
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
