help with starting problem, please!
Old Mar 19, 2007 | 01:27 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Got battery power to all accesories, but when I turn the key I get nothing. No crank. No click.
It used to crank a few times then start up.
Sound like ignition? starter?
Old Mar 19, 2007 | 09:28 PM
ryanz53's Avatar
Car: 84 Camaro
Engine: 81 oldsmobile 307 5.0L
Transmission: 700r
Axle/Gears: 3.75
Test starter.
I would say, test your starter.
Check for loose wires.
Also make sure that your battery terminals are nice and tight.
I have found that if the terminals are loose when you try to crank it the surge severs the connection and you get nothing at all.
I have had this problem in the past and all I had to do was tighten them up.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
