Hose Routing
Old Mar 20, 2007 | 06:30 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Hose Routing
Anybody know where these two hoses go to. One from the throttle body is located to the left of the tps sensor, and the other one is between the iac valve and the tps sensor and is connected to hard a emission hose which goes into a connector below the distributor but the other end of the actual rubber hose is cut.
Old Mar 20, 2007 | 08:48 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Hose Routing
the connector by the dizzy is the intake manifold vacuum treeusually it went to the cruiose control servo and another to the modulator valve on the tranny if so equipped and another to a vacuum can either on the firewall up as high as the wiper motor, or in the front corner of the front clip down low
if you tell me exact year make and model and engine then i could scan vacuum diagram from my book
good luck
Old Mar 21, 2007 | 03:21 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Hose Routing
The car is a 1985 Camaro Iroc-Z with the 305 Tuned Port Injection (LB9).
Old Mar 22, 2007 | 04:28 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Hose Routing
anybody have the vacuum diagrams
F-body-fan
Jan 12, 2023 01:49 PM
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
88CamZ
Oct 8, 2015 10:29 AM
