New engine up and running with heads question
Car: Dark Blue 1987 Chevy Iroc-Z Camaro
Engine: 5.7 350
Axle/Gears: 3:42
Got the new engine up and running finially and was trying to break it in and check everything when I noticed oil leaking as i looked under the car, with further investigation I can see oil seems to be coming from both heads and towards the rear by the firewall only. Would this be bad head gaskets or maybe just need retorqued ?
-1987 Iroc-Z camaro
-5 speed manual
-355 CI with Holley Stealth Ram intake and 58mm Holley Throttle body
-30lbs /hr Ford SVO injectors
-Holley Fuel Pump 255ltrs per hour
-High Volume Oil Pump
-AFR 195cc Heads with 2.02 1.6 valves & 1.5 Rocker Arms
-Comp Cams CS NR276HR-113 Camshaft specs are
- ADV DUR: 276 288
- DUR @ .050 224 236
- Valve Lift: .502 .520
- Lobe Sep: 113.0
-MSD Billet Distributer / MSD 8226 Blaster Coil
-ECM- 1227165 (updated bin file to $6E code and using a APYS bin) *EGR / VATS Disabled with injectors single and double fire changed to 30 lbs/hr
-Base timing currently set to 6 degrees
-Fuel PSI is at 40
-1987 Iroc-Z camaro
-5 speed manual
- ADV DUR: 276 288
- Lobe Sep: 113.0
-Fuel PSI is at 40
Re: New engine up and running with heads question
It's more likely either the valve covers or the intake end seals. I'd suspect the intake end seals especially if you used the rubber ones that come in the gasket set; and the valve covers especially if you used aftermarket ones, and above all if they're chrome.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
