leaking plugs
Old Mar 24, 2007 | 09:46 AM
curtistimmerman's Avatar
leaking plugs
Hey guys looking for a some suggestions ,i have a 92 cam with a 73 350 4bbl with accel plugs ,my #1 and #3 spark plug holes are leaking some oil out of them ,i was told it might be the accel plugs because they don't seat right in the head? or bad valve guides or seals?needing some some suggestions on what you all may think...thanks in advance....
Old Mar 24, 2007 | 11:20 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Re: leaking plugs
First, make sure you've got tapered seat plugs. If they're washer seat, they will leak. Second, figure out why you have oil in the chambers. Do a leakdown to see where it's coming from.
ljnowell's Avatar
Re: leaking plugs
spark plugs dont hold oil in, well, they arent supposed to. You need to look at the cause of the oil. Is it coming from the outside or inside? Is it a valve cover leaking? Does the vehicle let out a puff of smoke when you start it?? It could be valve seals, valve guides, or rings. Could even be a leaking intake gasket. Vacuum and compression testing would probably be in order, if an obvious source cant be found.
Infested
May 22, 2018 11:56 PM
LittleFranks
Sep 17, 2015 12:22 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
cstrobel65
Aug 15, 2015 10:19 AM
