stock heads?
Old Mar 26, 2007 | 02:12 AM
darkage's Avatar
Car: 1990 camaro iroc-z
Engine: 5.7 TPI
stock heads?
I have a 1990 camaro iroc-z 350 ...
Did the stock heads come angel'd or straight plug'd ? I seen a few posts and mine are straight ... but thought i seen the l98 came angel'd ....
The books i have i can't seem to find any spec's on the cam/heads ... i'd like to just buy a new pair of heads or just have the stock heads machined if they'd perform to par ...
Also the edlebrock victor jr 23 degree heads, would they be a good option for basing a build for a torque monster?
Old Mar 26, 2007 | 02:16 AM
90IROCJustin's Avatar
Car: 1988 Camaro (Z28 Clone)
Engine: 305 4bbl roch
Re: stock heads?
not sure if there straight heads or not, check the casting numbers to be sure, should be 083 if there stock and cast iron not aluminum
Old Mar 29, 2007 | 02:14 AM
darkage's Avatar
Engine: 5.7 TPI
Re: stock heads?
Ok, i've confirmed that they are the stock heads, i'm having rocker issues with them staying tight .... springs/rods and rockers all looked ok ... other than being stock .. i'd like to possibly dump some funds into a nice set of heads, that way adding a cam later to match "or should that be done at the same time" the heads.
Or would looking at new valvetrain parts such as rockers/rods and spring on the stock heads ? ....
Old Mar 30, 2007 | 01:11 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Re: stock heads?
If the heads are completely stock, then you are probably pulling the stock pressed in studs out of the heads.
Old Apr 9, 2007 | 04:43 PM
darkage's Avatar
Engine: 5.7 TPI
Re: stock heads?
Ok, if there pressed in and i've mananged to pull them out, the cars sitting in the garage ... can i buy a set of new screw in studs and get a pair of rocker arms to get it back on the road ?
Old Apr 9, 2007 | 05:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not that I've ever seen or heard. Pulling the head required to avoid chips in the engine.
Shouldn't be anything wrong with the rockers. Although it could be the rocker or rocker ball or pushrod or adjusing nut not locking causing the problem.
Press-in stud pulling out is a pretty good bet, though.
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
