still troubleshooting
Old Mar 27, 2007 | 01:06 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
well my car starts now, still has the weird idle problem. occasionally the rpms jump to around 1500 the SES light comes on and it runs "fine". soon after it slows down to about 1000rpm. touching the throttle kills it and eventually it drops back into the terrible idle then stalls. any ideas?
Old Mar 28, 2007 | 09:16 PM
89 Iroc Conv.'s Avatar
Re: still troubleshooting
Try checking the fuel pump I have a 89 Iroc conv. 305 tpi that is doing same thing I checked the fuel pressure and it was only 10psi at idle and it should be anywhere from 35-40 lbs
Old Mar 31, 2007 | 11:23 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
and try checking the fuel pressure regulator. diaphram might have busted
Old Mar 31, 2007 | 02:47 PM
Blue-Z28's Avatar
Car: 86 IROC-Z
Engine: 305 tpi
Mine did the same, replace both MAF sensors
Old Apr 1, 2007 | 11:44 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
i will check the fuel pressure this week when i have a moment. that seems like the probable cause? i also may have bad gas... that is my next move to drain the tank and get some fresh fuel. Blue- did you mean the sensors or the relays in the pic?
