Spark Plug Gap
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Spark Plug Gap
My car is an 85 IROC with a tuned Port Injection motor out of an 88 in it. I have the stock AC Delco plugs for it. Should they be gapped at .035 or .045?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Spark Plug Gap
AFAIK all were .045
look on your engine emission sticker under the hood
it will say
good luck
it will say
good luck
Car: 85 Iroc-Z
Re: Spark Plug Gap
wasnt sure since the motor was from a later year. my emission sticker is missing anyway.
Engine: 4.3L Z TBI
Re: Spark Plug Gap
ok i looked in the book and wow i am wrong
.035 was common later on in the 80s
i alkways assumed al sbc were .045 after 74
hum.
wonder why they wanted 10 thousandths smaller gap with later stuff
wierd,..,.,
1988:
vin code digit F 5.0L 5011 spark hap .035
timing 6* BTDC
fuel pressure 40-47PSI
vin code E 5.0L 5011 spark gap .035 timing 6* BTDC fuel pressure 9-13PSI
vin code 8 5.7L 5733 spark gap .035 timing 6*BTDC fuel pressure 40-47psi
hum.
wierd,..,.,
1988:
timing 6* BTDC
