305 TPI ECM programming
Old Mar 29, 2007 | 10:36 PM
svroom's Avatar
I want to remove the SMOG pump from the 88 Trans AM 305 TPI and would like to know if I need to get the ECU chip reprogrammed? I am also going to swap the 305 for a 350 and want to keep the TPI, I know I need to get the chip reprogrammed for that, but should I also go with larger fuel injectors? 24LB? What about the throttle body should I increase this size to 58MM?
Orr89RocZ
Apr 25, 2016 08:28 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
BOOT77
Aug 10, 2015 12:20 PM
drathaar907
Aug 6, 2015 04:20 PM
