is it a blow motor???
Old Mar 30, 2007 | 02:51 PM
chicagopd50's Avatar
Car: 71 camaro, and also a 91 camaro
Engine: 383 stroker
Transmission: t5
Axle/Gears: 3:73 strange axle
motor has 200 miles on it. i started it today and took it for a spin, and it bogged out and died on me, i started it up and started driving then heard a knocking sound.... car does not knock when on idol.... can anyone help me out.. motor has less then 200miles.... any help is appreciated... thank you
Old Mar 31, 2007 | 12:56 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: is it a blow motor???
knocking is bad...
lots of engines will not make sounds at idle and then "knock" under load...
most likely a rod bearing issue but you should adjust the timing first to see if your knock is really pre-ignition or detonation..
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
inferno15
Aug 29, 2015 01:48 AM
86White_T/A305
Aug 17, 2015 12:16 AM
