is it a blown motor???
Old Mar 30, 2007 | 02:51 PM
chicagopd50's Avatar
Car: 71 camaro, and also a 91 camaro
Engine: 383 stroker
Transmission: t5
Axle/Gears: 3:73 strange axle
motor has 200 miles on it. i started it today and took it for a spin, and it bogged out and died on me, i started it up and started driving then heard a knocking sound.... car does not knock when on idol.... can anyone help me out.. motor has less then 200miles.... any help is appreciated... thank you
Old Mar 30, 2007 | 03:01 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
Re: is it a blown motor???
well i wouldn't say "blown" but deffinetly hurting, check the obvious first, oil, and oil pressure are vital if you dont see oil pressure within the first 5 seconds of starting the motor turn it off. did you happen to "get on" the motor after the rebuild? because if you did you could have spun a bearing and thats why its knocking. ALWAYS wait 500 miles after a rebuild before realy getting on the motor.
Old Mar 30, 2007 | 03:31 PM
R4][N_M4l{3R's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 383 Stroker
Axle/Gears: 7 1/2 Inch 3.23
Could be a bearing. Drain your oil and check it out.
Ghettobird52
Jul 5, 2024 11:18 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
colton_carlson
Mar 8, 2019 12:21 PM
hydrolic144
Sep 8, 2015 06:55 PM
earlpote
Aug 28, 2015 10:42 AM
