Rough Idle...
Old Apr 2, 2007 | 11:52 PM
80smetalfan's Avatar
Car: 1989 IROC
Engine: LB9
Axle/Gears: 3.42 Posi
Rough Idle...
Just trying to get some ideas for troubleshooting a rough idle.
Pretty mild non-CC Q-jet 350. 305 heads and flat-tops, so high compression.
Blew out the lower radiator hose a few days back and overheated fairly badly. Car idled extremely smoothly before it happened, but has a rather erratic idle since, along with a loss of power. Also seems to be running hotter than usual since.
The plug wires are pretty new, don't look to be damaged in any way, so probably ok.
Just put in a set of new AC Delco pre-gapped plugs after the overheating, as I needed new plugs anyway. I'm planning on pulling them my next day off and checking the gap to be sure.
I've spent a fairly good amount of time fine tuning the ignition timing and idle mixture on the Q-jet.
Just looking for more troubleshooting ideas. Anything I've missed here? Obviously there are many more ignition parts that could be replaced trying to fix the problem, but I wanted to see if anyone had any ideas.
Thanks in advance.
db057
Jan 10, 2020 08:55 PM
Reid Fleming
Oct 10, 2015 09:56 PM
drumstixer
Sep 29, 2015 03:02 PM
Jlanz55
Sep 29, 2015 08:55 AM
amcnellis
Sep 16, 2015 04:16 PM
