Should I replace the front cover seal (timing cover seal)?
Old Apr 9, 2007 | 12:36 PM
pr1689's Avatar
Car: 86 Iroc Z28
Engine: 350 5.7L (rebuilding now)
Transmission: 700R4 shift kit
Axle/Gears: 3.73, 9-Bolt, stock posi
I have been building my engine on a stand and finally put the damper on. I thought it should have gone in further than it did so I pulled the damper back off and measured and found out that it indeed was seated all the way in where it was supposed to.
I had lubed the seal as well as the inside and outside of the damper where it meets the crankshaft as well as the seal. Since I've pulled the damper back off, does anyone think I should go ahead and replace that seal? I didn't think I would need to since it hadn't been run yet, but figured now is the time to ask rather than later and find out that I should have replaced it!
Thanks for the help guys.
Pat
Old Apr 9, 2007 | 01:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Should I replace the front cover seal (timing cover seal)?
No need to replace it.
Old Apr 9, 2007 | 01:09 PM
pr1689's Avatar
Car: 86 Iroc Z28
Ok great! Thanks for the reply, I appreciate it!
Pat
Old Apr 9, 2007 | 01:31 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Yep. You'll be fine.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
Amillionoh7
Aug 7, 2015 01:24 PM
