TDC -- BDC help..confused
Old Apr 10, 2007 | 11:08 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Hello everybody
I am very confused about this...dont know why I am..guess I am double guessing my self and now I am really confused.
Here the question, I have a 383 with Super Ram and Dual Sync Dizzy and an ATI Balancer, with full 360 timing marks.
Anyway I have the car set at TDC, the rotor is centered in number one spark plug, the number one port on the dizzy.
Anyways I need to put the motor at 25 deg BDC, for the dual sync fine tuning, so do I put the balancer at 25 or do I put it at 335. When I watch the rotor it appears that I must use 25 but is that really 25 deg ATDC, I am so confused here can someone please clear my old brain dust!!
Thanks in Advance
Old Apr 10, 2007 | 11:18 AM
Re: TDC -- BDC help..confused
Looking at the balancer from the front, the marks that extend clockwise from 0 (from 0 counting upwards) are BTDC, and marks that go CCW from 0 (backwards from 360 downwards) are ATDC.
Make sure as you approach your desired setting, that you are moving the engine CW, which is the direction it rotates while running; and of course that you're doing this at the instance of TDC that's #1 firing (remember, the engine goes through #1 TDC TWICE during a complete cycle), not the instance of TDC that's #6 firing.
Old Apr 10, 2007 | 12:15 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Thanks for the quick answer, I got it and understand it...thanks
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
92camaro350cci
Oct 14, 2015 09:29 AM
machinist21
Sep 5, 2015 03:03 PM
