Car Running Badly
Old Apr 12, 2007 | 07:17 AM
82Camaro355's Avatar
Car: 1982 Camaro Sport Coupe
Engine: Modded Carbed 355
Transmission: TH350
Car Running Badly
I put a brand new 350 in my camaro last month. It has a 750 Holley and a Holley Street Dominator intake. I am also using an Accel coil with Accel wires.
Now on to the problem. No matter how I adjust the carb, timing, or the fuel pressure the car seems to have no power. I figured with it being a new motor it should have tons. The car bogs really bad and sometimes backfires. It won't spin above 3500RPM and it struggles to make it that far.
Does anyone have any ideas what to do?
Old Apr 12, 2007 | 07:56 AM
MR NICE's Avatar
Re: Car Running Badly
Check rocker adjustment? maybe dizzy or timing chain is off a tooth.Also make sure coil is good.
Old Apr 12, 2007 | 10:30 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What did you use for a harmonic damper? Where is the timing tab on the front cover?
Old Apr 12, 2007 | 02:35 PM
Transmission: TH350
The harmonic balancer I used was a Fluidampr Streetdampr 6-7/8'' O.D.
When you mean where the timing tab is do you mean where is it physically or liek timing wise?
Old Apr 13, 2007 | 01:56 PM
Transmission: TH350
Anybody got any ideas?
Old Apr 13, 2007 | 03:52 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
How big of a cam are you running, a 750 sounds like a lot of carb especially if its a DP, im going to be running one on my new engine and i think it may be a little much
86IROC112
Aug 17, 2015 02:00 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
