TPIS BigMouth Intake
Car: 86 Iroc Z28
Engine: 350 5.7L (rebuilding now)
Transmission: 700R4 shift kit
Axle/Gears: 3.73, 9-Bolt, stock posi
I had bought the TPIS BigMouth intake and have a question about the felpro gaskets that came with it.
Before I bought the intake, I had planned on re-using my existing TPI intake and had bought the FelPro 47225 gasket kit for TPI. The gaskets in this kit are really nice and seem to be much better than what came from TPIS. I understand that I can only use the intake gaskets, but they are slightly different. They cover the intake just fine and all the holes line up perfectly. I would just prefer to use the better gasket.
Do you all think it would be fine to use the intake gaskets from the kit I had purchased or is it a wise idea to use the felpro's that TPIS provided?
Thanks,
Pat
Thanks,
Pat
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TPIS BigMouth Intake
If the holes line up and there's no gasket covering a port, then use whichever gasket you like better.
Car: 86 Iroc Z28
Ok great. I thought it wouldn't matter, but I wanted to make sure!
Thanks a bunch!
Pat
Thanks a bunch!
Pat
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
