Is this normal???
Old Apr 16, 2007 | 09:06 PM
Shane87irocz's Avatar
Car: 1987 IROC-Z
Engine: L-98 350 TPI
Is this normal???
I have a 87 Irocz, and when i turn the key to the ON position the fuel pump turns on for a second to two. THEN if i hit the brakes the fuel pumps turns on for a sec or two. It does this every time i hit the brakes. Is this normal????? Thanks Shane.
Old Apr 16, 2007 | 09:20 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: Is this normal???
Sounds a bit goofy but probably nothing to worry about...
Theirs alot of ways to make electronics do funny stuff from feedback.
Back in school we had a chevette that i figured out how to make the windshield wipers move with the turn signals by turning on certain combinations of things...
Old Apr 16, 2007 | 10:15 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
no that is not normal and shouldnt happen what have you played with under the dash recently?
Old Apr 17, 2007 | 12:20 PM
Car: 1987 IROC-Z
Well the only thing i can think of is: i took aout all the lights behind the gauges because i instaled glow gauges, code alarm about 4 years ago, and 2 auto meeter gauges in the A piller also about 2 years ago.
I FOUND A BAD GROUND. THIS IS WHAT IT DOES NOW: TURN THE KEY TO THE ON POSITION, FUEL PUMP TURNS ON FOR A SEC. OR TWO,
NOW IF I HIT THE BRAKE IT TURN ON ONE TIME, IS THAT NORMAL TO DO THAT ONE TIME??? BEFORE THE FUEL PUMP CAME ON EVERY TIME I HIT THE BRAKES.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
Stroopwafel
Sep 11, 2015 06:38 AM
