350 or 400
Old Apr 18, 2007 | 03:47 PM
camarodude87's Avatar
Car: 92 rs camaro
Engine: supercharged 355
Transmission: t-5
Axle/Gears: 342
350 or 400
My 350 just blew today on the way to work. So I was talkin to mechanic and he said that He has a 400. My question is, Is a 400 better or worse or should I stick with a 350
thanks Ray
Old Apr 18, 2007 | 03:51 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Re: 350 or 400
I vote for the 400. I am in the process of building a 421 or 434 I havent decided yet. Go with the 400, atleast I would
Old Apr 19, 2007 | 07:58 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Re: 350 or 400
400 all the way. I had a 355 and I love my 406 much better
Old Apr 20, 2007 | 01:37 PM
Shagwell's Avatar
Car: projects.......
Re: 350 or 400
Inches are inches, but there are a few draw backs. 400 have siamese cylinder walls, therefore they require a well working cooling system. You also want to be sure that its a 2-bolt main, not a 4-bolt. Unlike a 350, 4-bolt main 400 blocks are actually weaker, the thinner main caps(larger main journals than a 350) are known for cracking between the bolts. Also, anything over +.040 overbore needs to be sonic tested for wall thickness.
- There are other quirks associated with building a 400, but it si a good motor, and as I said, inches are inches. The only thing that beats cubic inches is cubic dollars.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
