fuel pump not priming any more??
Old Apr 20, 2007 | 12:58 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
so i have a 91 bird did a swap from the 305tbi to a 350carb. everything was working fine and the car is still running but i noticed that the pump isnt priming any more. after i did the carb swap it was still priming but in the last week or so i noticed its not. is the pump going out or what?
Old Apr 20, 2007 | 01:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: fuel pump not priming any more??
It won't prime without a working ECM.
Old Apr 20, 2007 | 02:54 PM
gapimpin's Avatar
Engine: 383 LT1
the ecm is still hooked up and it was priming before... i changed the engine in july and it just now quit.
Old Apr 20, 2007 | 03:23 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Pull the FP relay off and see if it will start.
Old Apr 20, 2007 | 03:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Maybe a bad fuel pump relay. It doesn't really matter though, if you've done the swap properly you've changed the distributor, so the ECM never gets reference pulses to turn the fuel pump on after priming. The oil pressure switch is turning the pump on after the pressure rises.
Old Apr 20, 2007 | 05:34 PM
gapimpin's Avatar
Engine: 383 LT1
just wanted to make sure it wasnt a sign that it was going out.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
92camaroJoe
Aug 13, 2015 06:07 AM
