Noise issue with engine or exhaust system
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
When I drive around with slight pressure on the gas pedal, I hear a metallic rattle noise, and if I lift my foot just a little, the noise goes away. Only to return if a press on the gas pedal again. The wife says it reminds her of a slinky (now I am showing my age). The noise mainly seems to be coming from the pass side near the firewall/engine compartment.
I know that this is not much to go on. I have done extensive mods to the car. The most recent change was bolting on Skute adapters and 4th gen aftermarket wheels. But in this case, if its the new wheels/adpaters, why would the noise come and go with gas pedal pressure, and its only on one side.
What does an spun engine bearing sound like?
What does a bad wheel bearing sound like?
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: Noise issue with engine or exhaust system
could be about a million different things...
rod/crank bearing, TC bolts, exhaust leak, lifters/rockers ect ect...
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Could it be the headers just barely hitting the A-Arm?
Car: 88 Firebird - SOLD!
Engine: 2.8L
Doc,
I usualy bring the car in the garage, apply emerg brake, roll windows down, start engine & power brake a little to see if I can get the noise to happen. This may help pinpoint the location. Could be a rotted heat shield around the cat rattling. Entice a friend to help with a cold libation and your problem may be located.
Corky
Corky
Car: '87 IROCZ
Engine: 395 ZZ4
Thank you for the responses. I can start this evening.
theshackle
Sep 17, 2020 08:26 AM
