From cap and rotor to ignition box?
Old Apr 21, 2007 | 11:06 AM
Bane's Avatar
Hey, i was wondering if there was a way to put an ignition box in my car. Do i need to change the distributor? The cap and rotor? Anything? What all is involved? Has anyone done this before?
Old Apr 21, 2007 | 11:25 AM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: From cap and rotor to ignition box?
To run an ignition box in your car you would need to take the module out of the distributor and replace it with the supplied wire, that wire then hooks up to the ignition box. everything else is just tach sender, power and ground.
Old Apr 21, 2007 | 08:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You only remove the module if you're using an old non-computer distributor with a 4 pin module. Otherwise, you leave the module in place.
There's no performance benefit to any sort of ignition box on a relatively stock engine.
Old Feb 6, 2008 | 07:37 AM
sprojam's Avatar
Car: 86 Z-28
Engine: 355 small block XR276HR roller cam
Transmission: TCI built 700r4 2000 lockup stall
Axle/Gears: moser axels auburn posi 3:73 gears
i recently installed a ignition box on my new motor, the motor ran great then one day i fired it up an the motor started to back fire an run extremely iratic. sence then i have been completely through the ignition system to find nothing. at this point i am looking at this box wandering if it isnt the problem ive been told when using these boxs the idiot lights in the box can check ok an the box still be bad any thoughts on this.
thanks Jim
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
cstrobel65
Aug 15, 2015 10:19 AM
