Removing AC...smog pump?
Old Oct 4, 2001 | 07:35 PM
Trent257's Avatar
what steps do i need to take when removing the AC, and the smog pump, what does it do, and can i remove it? im pretty new to cars
Trent
---Car---
89 Firebird
305 L03 TBI A4
t-tops
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's
Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
2 pioneer 12" ts-w303c subs (selling if anyone wants em email me)
Future:im profile 1200sx 900watt x 1, and a pioneer cdx-p1270 12 disk cd changer
Old Oct 6, 2001 | 07:55 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
the a/c is easy to remove, if you get an a/c delete pulley. you just take off the serpentine belt, take out the compressor, and put the pulley in it's place.
obviously you have to unhook all of the plumbing for the a/c first, but thats as simple as just checking out what's there taking it apart. just follow where all of the lines and everything goes and make sure you dont leave anything unhooked or open that shouldnt be.
the smog pump is a little harder. i am assuming that you want to take out the whole A.I.R. system as well. as far as the pump itself goes, you can either leave it there (just unhooked), or if your local gm dealer likes you as much as mine does, he pulled a LOT of strings and got me a smog pump delete pulley from out of canada somewhere. its an illegal part, so you may have to do some looking.
but, to take out the A.I.R. tubes, you just unscrew them from teh manifolds, and plug them with some brass plugs, or you can just cut the tube about 1/2" from where it goes into the manifold and flatten the hell out of it and screw it back in tempororily. then, just follow the lines again, and unhook everything.
there is an AIR tube going into the cat, so make sure you take care of that one too. without the AIR system, you wont pass emissions, and it won give you a power increase, but it just cleans everything up under the hood a LOT. same with the ac.
sorry this is such a broad description, but i dont have time to get into it now. also, its been a while since i took mine out so i dont remember specifics. shoot me an email at z28boy@twcny.rr.com if you have any questions.
here is a pic of the pulleys:
hope this helps
-Brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
z28boy.cz28.com
Central New York F-Body Association
z28boy@twcny.rr.com AIM - "Z28 Boy"
1998 Pontiac Grand Prix GT - 2 door, black
Old Oct 6, 2001 | 07:56 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
by the way, i have part numbers for both pulleys on my web page...its in the sig.
-Brian
z28boy.cz28.com
Z28 Boy's Avatar
Car: 1991 Camaro RS
sorry..double post
z28boy.cz28.com
[This message has been edited by Z28 Boy (edited October 06, 2001).]
Old Oct 7, 2001 | 02:30 PM
Trent257's Avatar
yea i think ill just do the ac for now, what do i use to plug the ends of the hoses?
i dont use the ac, i have ttops, i just want to get it out of there, and im changing the valve covers next weekend, so i might as well take it out while i have it apart
Trent
---Car---
89 Firebird
305 L03 TBI A4
t-tops
---Stero---
profile cl640 110x4
Old Oct 7, 2001 | 02:46 PM
Trent257's Avatar
another thing, what exactly does the smog pump do, if i just get a smaller belt and dont put it on the smog pump, will it work,
and is the smog pump under the ac pully right
Trent
---Car---
89 Firebird
305 L03 TBI A4
t-tops
---Stero---
profile cl640 110x4
[This message has been edited by Trent257 (edited October 07, 2001).]
Old Oct 7, 2001 | 06:14 PM
Trent257's Avatar
what is the red thing behind the ac pump, and the green crircle is 3 hoses that and connected together, any idea what that is
Trent
---Car---
89 Firebird
305 L03 TBI A4
t-tops
---Stero---
profile cl640 110x4
Old Jan 23, 2006 | 02:29 AM
fbomb's Avatar
Car: 87 formula ws6
Engine: mild 400sbc
Transmission: rebuilt 700r4 shift kit, 2400 stall
Axle/Gears: 4.10 open diff
sorry
sorry but this is the only thread i can find through the search button for removing ac, and it's pretty ill because i really wanna remove the smog pump along with it. I'd really like some more info on this, some qustions i have are
do i NEED to get a ac delete pully?
if so where can i get one?
if not what size belts will i need for a serpentine system?
which pully is the smog pulley?
my car is an 88 lo3 firebird incase you need to know
Old Jan 23, 2006 | 10:46 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
That thing you have circled in red is the heater valve. Also, you may want to have the A/C de-pressurized before you go pulling it apart.
Why remove the smog pump when you wont be able to pass smog and wont see any power gains from it?
Old Jan 23, 2006 | 11:24 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
The item in red is the AIR control/Diverter valve assembly.
It has two solenoids in it for directing the smog pump air.
First solenoid selects if smog pump is vented to atmosphere or is to be used. The other solenoid will select the path to the manifolds or the cat (if first solenoid is used) or something like that.
If you are taking off the smog pump thaen it goes to the trash as well along with the air tubes on the manifolds, tube to the cat, check valves and the tube that wraps around the back of the engine.
They all are for the AIR system.
One note, the wrap around tube is bolted on both heads at the rear. It probably will not come out without removing the intake.
The whole system removal won't show any significant gains but it does clean up the compartment if you don't need to pass emmisions. Better to leave it all there if you do need E-check.
Old Jan 23, 2006 | 01:57 PM
fbomb's Avatar
Car: 87 formula ws6
Engine: mild 400sbc
why?
the reason i'm removing the ac and smog is because i don't need the ac and want to clean up the engine bay, the smog becuase all i have to pass is the sniffer and i think i can handle it without the smog stuff, also part of it is already missing from my car from the previous owner i believe, i'm also putting hedman headers and y-pipe on so i won't have all that tubing floating around so why not clear the rest of the **** out,
can anyone answer my questions??
another is how would i route the belt if i could run the serp system without an ac or smog pulley, if it's possible?
Old Jan 23, 2006 | 08:57 PM
Firl's Avatar
When I had some work done on my 87, my local mechanic removed the whole a.i.r. system for me, without asking, was kinda nice. power steering, waterpump, alternator, was all I had on my system. I had to plug a couple vacum's after the removal, but that was about it.
Old Jan 24, 2006 | 02:18 AM
fbomb's Avatar
Car: 87 formula ws6
Engine: mild 400sbc
so your only running the three pully's also, if you could do you think you could get a picture of the engine for me for the routing of the belt, and if you happen to know the length of the belt??
Old Jan 26, 2006 | 09:55 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
diagram
i believe there is a diagram in the home page tech articles of thirdgen.org. i was looking at it too. but after hearing it's not gonna help performance, seems like a waste of time to me.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
