Pulley kits
Old Apr 22, 2007 | 11:24 AM
83-84z28's Avatar
Car: 1983 z28
Engine: '73 4-bolt 350
Transmission: t5
Axle/Gears: 3.42 with auburn and 28 spline axle
Pulley kits
Has anyone used or looked into the kits from GMPP for the serpentine conversion like this one
http://store.summitracing.com/partde...5&autoview=sku
I need to get a noew compressor and wnat a higher output alternator. Also my power steering pump altough working fime is the one that came with the car One other question i have is if I do this swap can i use the manifold hose from the serpentine setup for one of our cars to get my a/c up and running?
Old Apr 22, 2007 | 10:18 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
Re: Pulley kits
Anyone?
Old Apr 23, 2007 | 12:06 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: Pulley kits
Looked at it, saw the price, looked away....
Old Apr 23, 2007 | 01:16 AM
Pat Hall's Avatar
Re: Pulley kits
Wow! Somebody's been smoking crack. As near as I can tell, that setup looks virtually identical to the stock serpentine setup on 88-92 f-bodies, which you can pick up used all day long on the classifeds here for $100-$200. Even the March brand serpentine setups are too expensive in my opinion, but at least they look nicer than the stock stuff, and they're nowhere near that price. Hey, I just noticed you said it was from GMPP, so now I have no doubt that it's the same setup that came stock on 88-92 GM cars with a V8. If you have that kind of cash to blow, spend it on something better that you really need. Just get a used, stock serpentine setup for a ton cheaper.
Old Apr 23, 2007 | 06:58 AM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
Re: Pulley kits
i didn't notice it was the same setup i was just trying to get everything together because new compressor is about 250 and alternator is about 100-125 right there i've got about 375 so if you take into account that i'd still prbably need to get a water pump and power steering pump. or can i reuse my old pumps (water & p.s.)? a used setup would sure cost alot less but i dont know if the parts will be any good.I think i'll look around some more before making any sort of decision .
Old Apr 24, 2007 | 12:14 AM
Pat Hall's Avatar
Re: Pulley kits
Yeah, you'll definitely need a different water pump because the serpentine pumps run in the opposite direction of a standard, v-belt pump (i.e. "reverse rotation"). The power steering pump from a serp. setup would be easier too, since it's a PITA to remove the pulleys and swap them out. The good news is those approximate prices I quoted for a used setup come with most of the accessories nine times outta ten. A lot of times the seller will keep the alternator, since they figure it's worth something, but the rest of the accessories are usually included. Even if the water pump is no good, as long as you got a core, you can exchange it for a rebuilt one for a paltry 25-30 bucks at most parts stores. Just keep an eye out in the classifieds on this site. They come up for sale all the time here.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
BDR
Nov 7, 2015 03:05 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
