fuel pump relay
Old Apr 22, 2007 | 05:58 PM
speedped79's Avatar
Car: 1982 z28
fuel pump relay
is there a way to bypass this with tbi where the car will run? i tryed the fuel pump test connecter and tryed starting the car with it connected this way and the pump runs but the car dosnt start. and on a 1991 camaro rs can somneone post a pic of the fuel pump relay
thanks
Old Apr 22, 2007 | 06:43 PM
Vader's Avatar
Re: fuel pump relay
If the pump runs but the engine doesn't start, the problem is not likely the relay. Bypassing the relay isn't going to help (since that's exactly what you already did with the test connector).
You need to test fuel pressure and injector operation.
Old Apr 22, 2007 | 07:14 PM
speedped79's Avatar
Car: 1982 z28
Re: fuel pump relay
well, when i try to strt it the pump does not come on nor does it prime. i can make the pump come on steady with the test wire but it dosnt start. also i just installed a new fuel pump today because the old one wouldnt even come on with the test wire. also the one relay has a burnt clip so this is why im thinking its the relay
Old Apr 22, 2007 | 09:53 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: fuel pump relay
well just replace the relay as it is cheap enough and easy enough that way your not screwing around with wires and paperclips...
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
