Help please!WTF did i do?
Old Apr 11, 2007 | 10:05 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I posted this also in the elecrical board cause I`m not sure what my problem is.I pulled the passenger side valve cover to adjust a valve.I had to remove the breather and the plug wires,The valve cover is kinda hard to get off and there are some wires from the coil and distributer back there too.Started the car to adjust the valve which i still hadnt gotten around to yet cause now the car wont crank.It turns over but will not crank.Well it did once the first time I tried and died after about 30 seconds.I then realized i forgot to reconnect the plug wires.No biggie.so i reconected them and still wont start.Double checked and same result.Put everything back on the way it was....same peoblem.I pulled all the plugs I could get to from the top,2&4,And they dont looked fouled but cleaned them up and still want start.I cant find any wires or anything unplugged except for one two pronged plug that is dirty like its been unplugged for a while and i cant find where it would plug into.I cant really make heads or tales from all the wires but the coil and distributer are still hooked up and the injecters appear to be as well.I`m stumped.Any ideas.Thanks
Old Apr 11, 2007 | 10:26 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
Re: Help please!WTF did i do?
so it turns over but just wont fire? are you sure the plug wires are back in the right order? make sure non of the connections are loose, maybe try some starting fluid to see if that will at least get it going if not then you know you put something back on wrong since it wont get spark
Old Apr 11, 2007 | 11:45 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
The plugs wires are numbered and so are the terminals on the cap.I rechecked it like 4 times.Even if they were in the wrong order wouldnt start and just run like crap?
Old Apr 12, 2007 | 12:26 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
most likely yes it would start it would backfire and spurt really good though, had it happen to me before.
Old Apr 12, 2007 | 07:34 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
k.i.s.s. keep it simple stupid. Air, fuel, spark, compression. Which one is missing.
I am willing to bet its not compression? though maybe
fuel: is the pump priming? Are the injectors pulsing? Is the fuel pressure at the rail? Are the plugs sparking? at the right time? Is the distributor rotor working correctly? As in the two bolts that hold it on are they still doing so, like maybe one broke and the rotor is floping around? take the cap off and see.
Put some starter fluid in the throttle body and see if it will fire up. Maybe its cold start problem? If it doesnt start then you have a ignition timing problem like firing at the wrong time nor fire at all? It should itleast fire up with the alternative fuel source. Or maybe the plugs are junk? replace them and see. they are probably many more real issues but here are some to check and verify. I would do a complete compression check while your at it. I dont like to guess.
Old Apr 12, 2007 | 07:51 AM
MR NICE's Avatar
If it was running before you started I would check for a broken wire to the dizzy or bad connection, check for spark?
Old Apr 12, 2007 | 04:07 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
could be flooded, hold the gas pedal all the way down and crank it, this will shut the injectors off, besure to let off quick if it catches!
Old Apr 12, 2007 | 08:05 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Today 07:51 AM
I`ll try this,but i dont think I`ve got spark.I held a screw driver up to the plug wires and saw no spark.I`m pretty sure I`m getting fuel cause I get a slight gas smell after trying to crank it.I`m not sure if thats the best way to check for spark but I`m still learning and have limited tools.I`m obviously no mechanic but i can figure alot of stuff out with help and instructions,but I`m stumped and cant make heads nor tales of all these wires.I dissconected the msd box and wired it up stock with no change.Pulled all plug wires and distributer and checked it all out and made sure it was hooked up properly when I redid it.Cap has less than 1000 miles and wires only about 4000 miles.I`m just about ready to give up and have it towed to the shop and pay out the *** to fix something I`m over looking or too inexpereinced to find.
Old Apr 12, 2007 | 08:37 PM
slohand's Avatar
Car: 91 z-28 conv.
Engine: 350 vortec tpi crate
must be something simple. you must have unpluged something while you were working. recheck to make sure the coil is plugged up correctly. just recheck any wires you may have moved.
wish i could offer more but it must be something like that. Good Luck!
Old Apr 22, 2007 | 09:58 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
I got it.Fried the coil.Put stock one back on and fired right up.
83 Crossfire TA
Jan 3, 2016 01:26 PM
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
DARKmj16
Sep 9, 2015 04:07 PM
