Fuel pump
Old Apr 22, 2007 | 07:30 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Fuel pump
Would there be any reason to have an electric in tank fuel pump on an 87 camaro, that was carb'd and had a block mounted mechanical fuel pump? I shut my car off yesterday and when i went to change my oil today, there was a buzzing sound (like a electric motor) coming from the back of my car?
Old Apr 22, 2007 | 08:11 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Fuel pump
i didnt thinkg you could get a 350 with a carb in 87... and it would be silly to have a mechanical fuel pump along with the intank pump...
Old Apr 22, 2007 | 08:32 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Fuel pump
make sure it wasn't your hatch pull down motor...
Old Apr 22, 2007 | 09:15 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Fuel pump
In 87, GM put both the mechanical pumps and the electric in-tank pumps on the cars.
Old Apr 22, 2007 | 09:18 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Re: Fuel pump
It had a 305 carb's in it...i threw the 350 in it. The 305 had a mech. fuel pump on it so i threw it on the 350. When i was under the car, i heard a buzzing from the back of the car around the gas tank. that's why i was asking. If there isn't one in the tank, what would it be?
Car: 91 RS
Engine: 350 vortec
Re: Fuel pump
there you go another GM engineering marvel that seems unnecessary to some but GM liked the idea... for a while
Old Apr 22, 2007 | 09:19 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Re: Fuel pump
why both pumps? one for back up or is it for an attempt at better fuel regulation?
Old Apr 22, 2007 | 09:29 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Re: Fuel pump
I just went out and checked to see if it was still running again, and it was. It's not the hatch pull down motor. Makes sense why my last battery wouldn't hold a charge.
Old Apr 22, 2007 | 09:30 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Re: Fuel pump
To help prevent vapor lock, IIRC.
Old Apr 22, 2007 | 09:32 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Re: Fuel pump
So aside from unplugging it, how do i get it to shut off after i shut off the car?
Old Apr 22, 2007 | 09:35 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Re: Fuel pump
There should be a fuel pump relay under the hood. Look next to the brake booster. Sounds as if sticking.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
