fuel pump fuse?
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: fuel pump fuse?
well you might want to take a look around the battery tray i think it will be a 2 wire weatherpack connector screwed to the body with a blade fuse in it i think it will be a 20 too
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: fuel pump fuse?
I do have on that is mounted on the inside of the fender near the battery. And it is a 20 amp fuse in a weather pack like SpitotRs305 said.
92camaroJoe
Aug 13, 2015 06:07 AM
