Electric fan
Car: 84 Z28
Engine: 305HO
Transmission: Borg Warner T5
Axle/Gears: 3:73
Electric fan
ok i hooked my electric fan up to a switch with a in line fuse,and i put a 20 fuse in it and it blows it out.is a 20 big enough?what size is should be ok to run for my fan?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Electric fan
Electric fans need a lot of current. You'd probably looking at a minimum of 40 amps.
Not really the best idea to run it all through the switch either, you'd be better off with a switch and a relay.
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
Re: Electric fan
thanks that was a quick response,the switch i have is good for up to a 30 so i'll try a 30 in it 1st and if it blows that i'll find another switch good for 40
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: Electric fan
Apeiron is correct. A relay is a good investment for something drawing that much current
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
Re: Electric fan
well i put a 30A in it today and it didn't blow it so i should be ok with that.i don't have a 25 to try in it yet,and i live in the country anyway and i run no thermestate anyway so i only turn it on here and there
TMZIrocZ350
Oct 7, 2015 12:09 PM
