Question on dual valve springs comp 986
Old Apr 25, 2007 | 07:05 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
I picked up a set of springs, and was about to put them on, when I noticed that my heads have a step after the valve stem seal. The inner spring, would end up on the step thats about 3/8ths of an inch higher then the seat, where the outer spring would sit. Only reason I thought this might work is because the inner spring is a 1/2" shorter then the outer when not on the heads.
Thats the incorrect way to install comp 986's right?
If this is confusing, and to help make a better thread for others to look at down the road, I will make a video tonight showing what I am talking about, and possibly take some screen shots for pictures.
Old Apr 25, 2007 | 09:33 AM
Re: Question on dual valve springs comp 986
No there should not be a "step". The place on the head where the inners sit should be the same height as the rest.
Old Apr 25, 2007 | 12:43 PM
Damon's Avatar
The only "step" for the inner spring is on the underside of the retainer. In the valve spring pocket on the head both coils should be even/flat with eachother.
Old Apr 25, 2007 | 06:23 PM
Car: 87 Firebird
Engine: 5.3 76mm
Well thanks for the info guys, guess I dont need a video then. I kinda figured it wasnt right, so I went ahead and bought some Comp Singles
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
