Gas smell inside the cab?
Old Apr 27, 2007 | 02:46 AM
steve's Z28's Avatar
Hey guys. I've got a 91 Camaro Z28 with a tuned port motor. The last two months, I have been having a gas smell inside the cab. After the car sits for 30 mins to one hour I open the doors with the windows up and a whiff of gas comes from the inside. I had a smoke test performed at a repair shop. It's where they spray some type of smoke to detect leaks. If smoke is visible there's a leak. Anyway, nothing was found. After that was done, I experienced it again today. Where should I start tracking this problem? Should I purchase a gas detector analyzer?
Old Apr 27, 2007 | 04:10 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Gas smell inside the cab?
Some of hte 91 Camaros had bad welds on the filler neck of the gas tank. They had a recall on it, that might be your problem.
https://www.thirdgen.org/forums/body...call-read.html
Last edited by InfernalVortex; Apr 27, 2007 at 04:11 AM. Reason: Automerged Doublepost
Old Apr 28, 2007 | 08:51 AM
cheppibear's Avatar
Car: 1984 T/A
Engine: Chevrolet 355
Transmission: Borg Warner
Could also be a cracked Purge Canister...
Old Apr 28, 2007 | 07:30 PM
Is it that coffee can looking canister located in front near the driver's side headlight? Where do I look for cracks?
Old Apr 28, 2007 | 07:47 PM
Yes, I remember that recall. I took my car 1995 for that recall and the dealership said they find anything wrong. If it's a result of that defect, is there a company that makes a gas tank without that defect?
Old Apr 28, 2007 | 07:59 PM
cheppibear's Avatar
Car: 1984 T/A
Yes, you are correct. I would remove the hoses and take it out of the car to do a thorough inspection.
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
wayshegoes
Aug 17, 2015 12:00 PM
BurlyChev
Aug 16, 2015 09:08 PM
