Power Steering Trouble?
Old Apr 27, 2007 | 11:55 AM
Greenhough's Avatar
I have 1984 z28 and at low RPM i have trouble turning the steering wheel, but once i rev the motor up a bit it gets easier to turn. The power steering fluid isnt low and the belt is tight. Is this the power steering pump or is it something else??
Old Mar 1, 2008 | 10:42 AM
ToastedDoom's Avatar
Re: Power Steering Trouble?
I have exactly the same problem. Any solutions? I tried searching the forums and I found yours
Old Mar 1, 2008 | 11:22 AM
ljnowell's Avatar
It is possible that the pump is not producing enough pressure to provide enough assist. A buddy in a shop would be nice to have so you could get access to the proper gauges to check it. The readings are very high, it does require a special gauge. There are some things you can check, but nothing that will give you the definitive answer you are looking for.
Old Mar 1, 2008 | 11:25 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by Greenhough
Is this the power steering pump??
I'd start there. Welcome to the site, by the way.
JamesC
Old Mar 2, 2008 | 10:36 PM
So what are some possible causes, other than just a bad pump? Would loose belt tension cause this? Would a problem in the steering box cause these symptoms? What are some of those checks I can perform? I'd like to rule out as much as possible before I undertake the job of replacing the steering pump.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
