crank but no start
Old Apr 27, 2007 | 03:24 PM
70gmc's Avatar
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
crank but no start
hey guys i got a 355 sbc pretty built double hump heads. roller rockers cam headers scat crank H beam rods MSD igniton and dizzy.........
I pulled the oil pan and timing cover to replace a gear drove with a double roller. I set the double roler up with the crank dot at 12 oclock and the cam dot at 6 oclock. and the dizzy was pointing at number 1 cylinder.. Now it will crank but not start. It didnt even act like it wanted to fire so i advanced the dizz a little and now its trying and poping out the exshaust. What could this be any ideas?
thanks
Old Apr 27, 2007 | 03:54 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: crank but no start
well sounds to me like your timing is screwed up.... but then again your flux capacitor must be out of whack also with the new double roller...
Old Apr 27, 2007 | 08:10 PM
70gmc's Avatar
Engine: 383 stroker
Transmission: 350TH
how do i check and see. how do you tell if your 180 out. Im not sure the truck has a flux capacitor. whats it do?
thanks
Old Apr 27, 2007 | 08:14 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
haha im not sure if he's joking about not sure if his truck has a flux capacitor or not but wow thats funny
I love back to the future haha
Old Apr 27, 2007 | 08:23 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
It def. sounds like timing to me. Just turn your "dizzy" counter clockwise enough till it starts and adjust timing from there.
Old Apr 27, 2007 | 09:34 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
The flux capacitor allows you to time travel provided you hit 88mph. That way you don't have to wait for lightning strikes.
PS if you go back, buy some shares in IBM. If you go forward, tell me if I ever got my car started, or died trying.
Old Apr 27, 2007 | 09:41 PM
Car: 91 RS
Engine: 350 vortec
70 gm... i have to say that is the best answer I have heard in a long time to that...
okay here is the best way pull the dist. get your timing chain off align both dots at the 12 0'clock postion put the chain back on then stick the dist. back in with the rotor pointing as close to the #1 terminal as possible then get out the timing light and set the ignition timing
right now you basicaly are 180 off
bryan623
Mar 22, 2021 06:43 PM
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
