Original Specs for 1988 Engine L89 and LB9
Old Apr 28, 2007 | 06:24 PM
patgta's Avatar
Hi everyone,
Is there a site that has very detialed information / specs about a 1988 L98 or LB9 engine. Even as detailed as the rating of the valve springs, etc. I'm thinking about rebuilding the engine thats why.
Pat
Old Apr 28, 2007 | 07:49 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Original Specs for 1988 Engine L89 and LB9
This site only shows the spring pressure, not the rate. It has rebuild specs.
1982-1992 firebird engine specs
Old Apr 29, 2007 | 02:43 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Look at getting the Helm manual for a 1988 Trans-Am.
You shouldn't need too much specifics on the L98, since you'll probably be upgrading some parts right? Also, the rest of it is generic to SBC sorta thing.
Old Apr 29, 2007 | 06:58 PM
patgta's Avatar
thanks for the site supervisor42;
and your right sonix i will be replacing some of the parts however i just wanted to know some of the original specs just to compare.
I have a quick question about valve springs but I'll start a different thread for that.
Thanks for your help guys
Pat
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
