Changing Cylinder Heads
Old Apr 29, 2007 | 03:20 PM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
My valves are going and I have been wanting to change my heads with a alumium set. Can I get some tips and tricks before I do this. I only have my old Haynes for information. Can I get some advice to make my job easy.
Also will my compression change with new heads. My engine currently has high compression?
Old Apr 29, 2007 | 07:54 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Changing Cylinder Heads
dont just change the heads... if you have burned up the valves then it is probably time for a rebuild... with just changing the heads you will probably start having blowby issues even thought the 100k+ mile rings are still sealing will they with the added compression of fully sealing valves?
as long as you retain the same CC combustion chamber your CR shouldnt be affected...
no stock engine has "high" compression that would be a trick used to sell the car
ADVICE: Have another car on standby cause you will need to go some where as soon as you get the heads off... it always happens
Old Apr 29, 2007 | 09:29 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Buy a good engine book and read it carefully. You can learn alot from a good book. I have several.
Old Apr 30, 2007 | 11:58 PM
magadith's Avatar
Engine: 305 4bbl
I had a compression test done to it. From what I remember there was a average of 140 psi per cylinder. The original heads were shaved, which was a problem with sealing the air intake manifold. And I couldn't use regular unleaded gas because it burned to hot for my engine.
I wish I had the shop manual.
NinjaNife
Aug 23, 2015 11:49 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
