heater core hose relocation
Old Apr 29, 2007 | 09:40 PM
scottyb123's Avatar
Car: 84z
Engine: 305 HO carb
Axle/Gears: stock
there are 2 hoses coming from the front of my engine (one is hooked up to the intake manifold i think)that i need to relocate, if i can. both go into the firewall, so i assume it is for the heater. im cleaning up my engine bay, and im removing the AIR system, and now i have these two rubber hoses going over my left valve cover... if anyone can help me to relocate them or at least tell me what they do and are for it would be appreciated...thanks
Old Apr 30, 2007 | 07:12 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: heater core hose relocation
They do go to the heater core.
You can just extend the hoses with couplers to get them out of the way. You could even just take the heater core out of the mix (no heat) and re-route. That'd be the cleanest.
Old Apr 30, 2007 | 05:19 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
if you rmeove them then you can use a regular old plumbing pipe plug to plug the hole in the waterpump
but how to plug off the radiator one is up to you
good luck
sheachopper
Jul 31, 2019 11:27 AM
meeklay812
Oct 1, 2015 03:46 PM
