305 LG4 / Vortec cylinder heads / Comp cams XE262H
Old Apr 30, 2007 | 09:09 AM
iky's Avatar
iky
Car: 1982 TA
Engine: 305ci
Transmission: T4
Axle/Gears: 10bolts/3.43
I would like to know if 12558060 Vortec cylinder heads will be ok with Comp cams XE262H http://www.compcams.com/Technical/Se...umber=12-238-2 on my 305 LG4 (TA 82) ?
thanks
Old Apr 30, 2007 | 10:44 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: 305 LG4 / Vortec cylinder heads / Comp cams XE262H
Those heads should be fine for that lift on that cam. It's a generally mild lift and the 1.25 springs should hold to at least .500. Other heads with the same diameter spring are rated to .525, so you should be in the clear.
These are vortec heads though so just make sure you have an intake manifold that will match up.
Old May 1, 2007 | 01:50 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Stock heads (especially Vortecs) are often limited to .480" lift or less due to retainer to guide clearance. .469" should be okay, but it's always a good idea to check each valve for travel.
I'm also not sure those the 981-16 springs will fit over stock guides. They may need to be cut (which should solve any potential lift problems).
Old May 2, 2007 | 12:30 AM
77monte's Avatar
Car: 77 Monte Carlo, 89 Firebird Formula
Engine: 355's
Transmission: TH350's
Axle/Gears: 10 bolt 8.5 3.73, 9 bolt 3.27
I had to cut mine down when using those springs... i ran a cam without doing anything to the heads first that was around the 460-470 lift range and eventually it was destroyed because i didn't cut down the guides first like i should have..
Old May 2, 2007 | 12:14 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
i heard .470 lift with the stock small diameter springs... the stock vortech springs suck and u should purchase the higher lift from scoggin that are good for .525 with higher seat pressures and better springs as well. they are kinda expensive at 330-370$ a head, my dad just purchased these a few months back. upgrade to the scoggins they do all the machining and guess work for u.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
TreDeClaw
Aug 14, 2015 06:58 PM
