intake leak. help!!!
Old Apr 30, 2007 | 01:22 PM
85SILVERBULLET1's Avatar
Car: 85 Trans Am
Engine: 383 ci
Transmission: Liberty Geared Tko 600
Axle/Gears: Moser 9" 4.11 gear wavetrac locker
i have a stroker small block wth a professional products aluminum intake and i cant get the front of it to not leak. what kind of gap are you supposed to have between the intake and the block? o yeah i am not using the rubber gaskets that come with the gasket kit and i have used several diff types of rtv and i just cant seem to get it right. what do you guys think?
Old Apr 30, 2007 | 06:31 PM
Detroit_Z28's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: TH350
Re: intake leak. help!!!
ideally as small a gap as possible, I usually use a liberal amount of permatex high-tack or equivalent, but with used, pitted intakes sometimes I've had to use RTV around the water passages. Make sure you have a continuous bead around the water passage, and that there isn't some weird surface imperfections on the head or intake.
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
rjcme
Sep 5, 2015 01:23 PM
