Oil Cooler?
Old May 1, 2007 | 09:19 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Oil Cooler?
So this is a problem im having with my 90 RS with the specs in my sig. Pulled the engine to do some work on the engine bay and install a new TC. I noticed this before when the engine was in the car but now im trying to figure it out. I attached a picture of the oil filter and right above it I have , im assuming, a oil cooler since there was coolant dripping out of the ports. It the 2 inlet block right above the filter in the pic. So is this a pump for running an oil cooler or am I just confused lol. If it is an oil cooler how do I go about routing the lines for that? Thanks a lot!
http://images1.filecloud.com/433860/DSC01707.JPG
Steven
Old May 1, 2007 | 09:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil Cooler?
The two hose barbs above the oil cooler are for the factory oil cooler. The mangled thing in the block above that looks like what's left of a block heater.
Old May 1, 2007 | 09:48 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Oil Cooler?
Ah ok thanks, so do I need to buy a radiator for cooling the oil also. Thought it was wierd cauyse I dont have that on my 85
Old May 1, 2007 | 09:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Oil Cooler?
From the factory coolant for the oil cooler flows through the normal rad.
Old May 1, 2007 | 10:23 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Oil Cooler?
Alright thanks a lot and thanks for the quick responses!
tyeo098
Nov 30, 2015 06:27 PM
1992Z28!
Nov 19, 2015 07:33 AM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
