ATTN: gmtech etc
Old May 3, 2007 | 07:02 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
ATTN: gmtech etc
hey guys sort of wierd question i recently swapped tpi into my 1984 z28 (basically an l98 swap)
anyway went to start . just crank but no start, have spark but no injector pulse confirmed power and ground to injecotrs as well as ecm ground, tried unplugging tps and maf to double check still no injectors
i checked the Refernce pulse purple/white wire and got some wierd readings sometimes i had 1 volt even with the key off sometime i would get half a volt
so went went to remove the old ignition module and presto the connector for the pickup coil crumbled in my hands ahhhh pick up coil reads ok 700 ohms
are those leads reversable or not one is marke n and one is maked p on the module but i have no way of know which wire is which
ps i checked i had continutiy in that purple/white wire from the dist to the ecm too by the way
PLEASE HELP
steve
Old May 7, 2007 | 10:55 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: ATTN: gmtech etc
the pickup coil leads can be put on either way on the module, but you may have problems if they are reversed. i have seen the leads being reversed cause anything from a no start to misfire & poor performance. sometimes they run fine & you may be ok, but i would recommend to go a head & replace the pickup coil to be on the safe side.
NEEDAZ
Car Audio
Jun 23, 2005 07:15 AM
Marin
Sep 15, 2003 11:06 PM
90TA
Jan 20, 2003 09:05 PM
Rob P
May 3, 2001 09:48 PM
Grim Reaper
Dec 1, 2000 03:52 PM
