charging issues, March alt pulley.
Old May 7, 2007 | 10:37 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
i am having some charging issues with my march pullies and I was wondering if I put my stock alt pulley back on would that cause anymore problems or will if possibly "fix" it?
Old May 7, 2007 | 11:46 PM
Re: charging issues, March alt pulley.
come on guys! someone HAS to know this?
Old May 8, 2007 | 12:20 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
if your march pulleys slow the alt down, then that could be the problem.. then again, it could be coincidence and your alt is dead..
Old May 8, 2007 | 12:36 AM
Funny.....But it still doesn't answer my question.The alt is brand new as well as the battery.The car charges normally when I'm driving around but at idle the voltage drop considerably.I have to foot stall the car up to 1000 rpm's to get the alt charging again.So just for clairity if I put my stock ALTERNATOR pulley back on will this help my situation? Would this speed up my alt enough to work as normal?
Old May 8, 2007 | 12:47 AM
5678TA's Avatar
Car: 1984 Trans Am
this is the breakdown for your stock alt pulley to work..
stock alt pulley must be smaller than the march unit
march crank pulley must be stock size OR larger..
Old May 8, 2007 | 01:38 AM
Sooo...Since If I put my stock put Alt pulley back on and left the rest alone it would be ok right or I have to put BOTH my stock alt AND stock crank pulley back on for it to work? I already have the stock Alt pulley back on the car but It was to late to test it.
Old May 8, 2007 | 04:37 AM
5678TA's Avatar
Car: 1984 Trans Am
if the stock alt works good, then you can leave the march crank.. if it still needs more rpm, then obviously the stock crank pulley is needed..
basically for the best results, you want the biggest crank pulley and the smallest alt pulley.. this will yield the fastest rpm at the alt which equates to charging at lower rpms..
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
