Strange smoke.
Old May 7, 2007 | 09:31 AM
devilfish's Avatar
Strange smoke.
Hello
Got some smoke from my new engine, hope you can tell me if this is normal or not ( just 20 miles on it ).
This happens when the car sits outside on a cold night. And when I start it up the next morning.
At first I got no smoke ( or whery little ), then after around 1min, I get white smoke frome the exhaust. This continues around 1-2 min, then it stops and the exhaust is "normal".
I dont loose any coolant, or oil. And the plugs look good.
My theory is that this is condensation from water traped in my headers/exhaust. And after 1 min the heat is enough to let it condens.
But im no expert..
thanks
Old May 7, 2007 | 12:34 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: Strange smoke.
White smoke is burning water/antifreeze.
If the antifreeze level isnt dropping then its gotta just be the moisture in the pipes/mufflers
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
KCG
Sep 23, 2015 09:05 AM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
