383 build help.
Old May 7, 2007 | 04:52 PM
jetblast's Avatar
Car: 91 z28 convertible
Transmission: 5 speed
383 build help.
Im about to start building a 383, and Im looking for a block to start the project. My question is, Can I build this out of a 2 bolt main, or do I need to get the 4 bolt main for a stroker. Thanks
Old May 7, 2007 | 05:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 383 build help.
Either one is fine.
c4mo's Avatar
Re: 383 build help.
You use either, the theory is that a 2 bolt can handle around 500 hp, and a 4 bolt can handle a bit more. The best thing to do would be to buy a 2 bolt block and get splayed main caps, but you have to align bore it. If you do not have a block already why not try to find a 400 block and build a 406 or bigger.
Old May 7, 2007 | 05:27 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: 383 build help.
Good luck finding a 400 block thats not already bored
Old May 7, 2007 | 05:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 383 build help.
You can, but it's a lot of money, and not really necessary for a street engine.
Old May 7, 2007 | 05:32 PM
jetblast's Avatar
Re: 383 build help.
THanks for all the help guys . I found a couple of deals on craigslist. Ill start on this as soon as PAYDAY
Bubbajones_ya
Jul 6, 2024 08:32 PM
Jorlain
Oct 8, 2015 01:57 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Numbah-1
Sep 12, 2015 08:57 PM
