Thermostat change
Old May 8, 2007 | 12:08 PM
Jake52's Avatar
Transmission: auto
Thermostat change
I plan to replace the thermostat and coolant sensor on my 305. The books I'm referencing say to drain the coolant. Is this necessary? Years ago I replaced a thermostat and I don't remember draining the coolant. There was just a little overflow when the top hose was removed.
Old May 8, 2007 | 01:03 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: Thermostat change
i just did a thermostat last sunday. also drained and flushed all coolant. no u dont have to drain it, but if its been a while why not.
Old May 8, 2007 | 04:36 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
It would also be a good idea to flush your cooling system since it probably hasnt been done in a long time. Draining the coolant will just make the job cleaner.
Old May 8, 2007 | 05:46 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Just drain it 1/3 of the way. You just need it so that the level of the antifreeze is below the intake manifold. You dont have to drain it, but once you pull the top hose, antifreeze is going to spill all over your intake.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
hydrolic144
Oct 4, 2015 08:23 PM
BAMiller
Sep 14, 2015 06:38 PM
z28guy134
Sep 1, 2015 11:50 PM
perZ
Aug 15, 2015 01:17 PM
