What cubic inch is this? 4.145 bore 3.75 stroke
Old May 10, 2007 | 08:59 PM
FastEddiesIROC's Avatar
Well i tore my motor apart, i measured the bore and it came out to 4.145, When one on the pistons was a BTC, I measured from the top on the piston to the top of the block and came up with 3.750 which would indicate a 3.75 stroke. This is also in a bowtie block. What cubic inch would this come out to, My guess is 406 but i was informed that the max intended cubic inch for the bowtie block is 391....Thanks guys
Old May 10, 2007 | 09:03 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: What cubic inch is this? 4.145 bore 3.75 stroke
a 406 is 4.155 bore and 3.75 stroke.. so maybe a 404ish.. and i'm sure you mean BDC.. bottom dead center, not BTC which is idk..
Old May 10, 2007 | 09:21 PM
HAHAHA Yeah i meant BDC.....I measured it with a digital caliper because I dont have a dial bore gauge as of right now, so i'm thinking if i can actually measure more down inside the bore it will probably be 4.155.....who knows
Old May 10, 2007 | 10:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The volume of a cylinder is the area of the base times the height. The area of the base is pi times the radius squared. The radius is one-half of the diameter.
(4.145"/2) squared times 3.14159 times 3.75" = 50.60 cubic inches. Times 8 cylinders = 404.8 cubic inches.
Basically, it's a 400 with a .020" overbore.
Or, if it's actually 4.155" bore, 400 with a .030" overbore. . .
Old May 10, 2007 | 11:36 PM
rhamm1320's Avatar
I don't like math that much, here is the easy way
http://www.virtualengine2000.com/Calculator.htm
Old May 11, 2007 | 12:02 AM
five7kid's Avatar
Math fits in this category:
"Those who don't know will become the slaves of those who do."
And,
"Give a man a fish, and he'll eat for a day. Teach a man to fish, and he'll eat for a lifetime."
Time to learn more than what buttons to push and know what's behind them.
Old May 11, 2007 | 12:14 AM
5678TA's Avatar
Car: 1984 Trans Am
i like that one.. words from a wise man..
Old May 11, 2007 | 11:34 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
And,
Good man.
Must be an engineer
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
