Rebuilt 355: estimates?
Old May 11, 2007 | 04:38 AM
AUSSIROC's Avatar
Car: 1999 subaru forester GT (urgh)
Engine: ej20 turbo
Transmission: 5speed
Axle/Gears: 4.11:1 awd
The 350 in the IROC has just been put back in. Rebuilt with the following stuff:
- Hot-tanked block bored .030" over to 355ci
- rebuilt stock heads with reground and reseated valves
- New LT1 valvesprings with stock rockers and pushrods
- Flat top cast pistons, cant remember the exact minor compression increase
- Double row roller timing chain
- balanced stock crank, rods, and pistons
- summit (flowtech?) shorty headers with header wrap
- new harmonic balancer
- mildy ported tpi plenum (removed wall at front).
- removed egr diaphram from intake manifold
- removed pollution gear etc
- ac delete pulley
- smog delete pulley
- new acdelco plugs & 8.5mm msd wires
- Pure motorsports braided fuel line kit
- K&N filters
- stock water pump, new bearings & pretty much stock everything else..
What hp/tq figures can i expect from this pretty conservative combo?
Old May 11, 2007 | 07:44 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Rebuilt 355: estimates?
A little more hp than stock
Old May 11, 2007 | 10:14 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yeah, the headers are the only thing that made any real HP change. Assuming it's still a stock cam, which you didn't mention.
Old May 11, 2007 | 11:12 AM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
It will definately perform a lot better than your stock engine did, I would probably say a 20-30hp gain
Old May 11, 2007 | 08:34 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, it'll be back to like new condition, so if you had bad rings and it burned out and had a fair bit of blowby, that'll be fixed, but performance wise, maybe 20 HP if you're lucky. Cam and heads are where the power is, and it doesn't seem like you did much/anything to those.
Old May 12, 2007 | 02:53 AM
AUSSIROC's Avatar
Engine: ej20 turbo
Yeah stock cam too. I was thinking an optimistic 15 hp, but yeah it runs a lot smoother, but i'm still breaking it tho.
Def worth it, but now the bottom ends fresh, i can save for some heads and cam, intake, etc. So it worked out good.
BTW the drivers side (your pass side) headers are pretty butchered to clear the steering shaft, so the gains are probably negated anyways!
Old May 12, 2007 | 03:21 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
you have yourself a very nice stock motor
Old May 12, 2007 | 07:05 AM
AUSSIROC's Avatar
Engine: ej20 turbo
Hey, the Chevy Orange engine paint's gotta be worth 5 hp alone!
Old May 13, 2007 | 01:00 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
nothing wrong with a mostly stock rebuild man. either way you would still kick my ****
Old May 13, 2007 | 03:29 AM
AUSSIROC's Avatar
Engine: ej20 turbo
Yeah it runs good now, but as soon as the funds top back up, it's stock-no-more!
Sweet guys thanks
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mrbird
Oct 20, 2015 03:43 AM
KO1
16
Oct 15, 2015 05:00 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
