New Steering Shaft
Old May 14, 2007 | 07:12 PM
82IROCZ's Avatar
Car: 1988 Iroc Z
Engine: SBC 355 crate motor
Transmission: T56 6-speed
Axle/Gears: 7.5 stock Disc rear.
New Steering Shaft
My rag joint is bad on my 82 camaro and it cant be replaced without replacing the whole shaft new from gm. My question is there any aftermarket companies that make a steering shaft for a third gen where the rag joint are replacable without replacing the whole shaft. please let me know.
Old May 14, 2007 | 08:11 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: New Steering Shaft
who said you can't replace the shaft w/o buying new??
The shaft collapses a bit, allowing removal w/o removing the gearbox. When i stabbed my iroc gearbox i had planned to replace the ragjoint, but ran out of time. now it sits in my closet, ready to be put back together.
Only hard part of replacing the ragjoint is cutting out the studs that hold it in. Then its just four 1/4 bolts and a new ragjoint later, you're all done. Ragjoint can be had at autozone in the help section. don't remember PN offhand.
need any more info let me know.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
6998poncho
Sep 25, 2015 02:56 PM
Night rider327
Sep 25, 2015 04:19 AM
