Opinion on fuel injectors cleaning shops?
Old May 16, 2007 | 11:42 AM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I was looking at this place...
http://www.witchhunter.com/index.php4
They charge $17.00 per injector. Anyone ever used them?
Anyone recommend another shop?
thanks
P.s. I should have checked the subject for typos before saving...
Old May 17, 2007 | 02:30 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
Re: Opinion on fuel injectors cleaning shops?
No opinions, huh?
I guess I'll have to answer my own question...I sent them off to WitchHunter today.
Old May 17, 2007 | 04:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i dont know anything about witchhunter but i have heard good things about Fuel Injection Specialties.
i have heard they only charge like 10-12 bucks an injector but i'm not 100% sure
let us know how witch hunter is
Old May 17, 2007 | 08:55 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
which injectors are you getting cleaned, the ones on the vette?
Old May 17, 2007 | 10:15 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
No, an extra set for my ProJection 4. They should be 85 lb/hr.
I've been trying to find my "missing" HP and recently installed a Holley 830. It helped some (guess 30-50 HP), but I get the same result by increasing my fuel pressure by 25% on the TBI. So maybe I just need a good cleaning. WTH, I figure it can't hurt.
Old May 29, 2007 | 02:37 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
Just got my injectors back.
Witch Hunter had the 1 to 2 day turn around that their wqeb site promised.
The injectors are individually bagged and numbered (on the bags) so that I can tell which injector is which compared to the flow sheet provided.
I DID NOT get any prior-to-cleaning flow numbers and was origionally upset because that is one of their promised services, so that you can make a before and after comparison. When I sat down and read all of the documentation they provided I found a note that all 4 were stuck closed, so no pre-cleaning tests were possible.
All of the o-rings were replaced and the injectors look like new. The old o-rings were returned. The injecorts varied from 944 to 996 cc/min (90-95 lbs/hr)@20PSI after cleaning. A 6.5% difference that Witch Huner said is typical with this type of injector.
All in all I am pretty happy with the service, I expect I will use Witch Hunter again. I'll probably put these on my car this weekend and then send my other set in to be cleaned. Since they are working now I should get some before and after numbers this time.
bryan623
Mar 22, 2021 06:43 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
